D dschag Lurker Feb 2, 2011 #1 sorry, should be simple answer but i could not find in forum: what software do i need to connect droid pro to pc (xp). thanks. dan
Frisco =Luceat Lux Vestra= Feb 9, 2011 #2 dschag said: sorry, should be simple answer but i could not find in forum: what software do i need to connect droid pro to pc (xp). thanks. dan Click to expand... Hello dschag. You only need the drivers for your Droid Pro installed into your Windows computer. http://www.motorola.com/staticfiles/Support/Experiences/Global_Drivers/USB_Drivers_bit_4.7.1.zip Then be sure to enable "USB debugging" in menu > settings > applications > development > check box. Select "copy files to/from computer" when prompted after connecting your device to the computer via USB cable.
