Connection Problem
spiz
Android Expert
Hey guys... my wife's BH2 is having connection problems. When using 3G/Edge/etc... she's unable to access anything that requires a connection. Facebook, her weather widgets, gmail, browser, etc...
I assumed a factory reset would work, but is there anything I can before resetting? Thanks!
Edit: Nevermind. Apparently I can get connection now. Facebook for Android is still giving me that connection prob.
Try disconnecting the battery for 5 or 10 min after the factory reset, that sometimes helps.
Also, has to phone suffered any drops? if the above doesn't help you might want to consider in-store technical support.
Let us know if you have any progress.
