openskies2009
So, I recently purchased my brand new Samsung Galaxy 3 with Jelly Bean installed with a brand new unlimited data plan from sprint.
I quickly found out that there isn't any native way to look into the file system on mac so I installed Android File Transfer. This worked until I tried to root the phone a few different ways with scripts but it kept getting stuck at
waiting... If you get stuck here, try another USB port.
* daemon not running. starting it now *
* daemon started successfully *
When I used heimdall it got stuck at
Initialising connection...
Detecting device...
Failed to detect compatible download-mode device.
I tried to test an app with eclipse but it returnes that the connection wasn't made.
Now, the Android File Transfer doesn't even let me through saying
No Android device found
Please connect your Android device with a USB cable to get started.
Things that I have tried but doesn't work;
Re-set my Android to factory defaults.
Turned on USB debugging
Enabled install from untrusted sources
Toggled USB PC connections modes MTP PTP
Before I take a drastic measure in formatting and re-installing my macbook, can anyone push me some advice?
Thank you in advance!!
Detecting device...
