Contact help
nikkit2
Okay so on my Google Ideos Huwaii Phone (don't know the model number) I had saved my contacts to a certain email, but the contacts were never synced to the email. Because I recently changed the password to this email, I removed it as an account and then added it back in and I noticed ALL OF MY CONTACTS WERE GONE. Is there any way to get them back? Thank you!
Hi nikkit2, You can Export your Contacts to your SD card and you won't lose them. Your Contacts will be on your SIM card and it pays to copy them to your SD card for obvious reasons. Neil.
Hello, i have htc desire sv phone, by mistake i had deleted all the contacts from the phone, my phone was not synced with the gmail nor i had backed up the contacts, as going by the rumours it is said that contacts can be retrieved from the phone memory, what is the procedure plz do let me know
Hi soulbachelor, That sounds like real bad news. If you had not used your Google account to backup and you hadn't exported your contacts to your SD card - they're gone! :o
It pays to have a File Manager App which will move apps to your SD card. There is also an App called 2SD (App Manager111). This one shows which Apps can be moved to your SD card.
You can also Sync to your computer all info you want store including Contacts. Unfortunately I think you will have to rebuild your contact list because you Deleted them from your phone memory. You could try and search for them through your computer to USB cable to phone. Neil.
Respected Neil, thank you very much for the reply, but what about wondershare app, does it help to recover deleted contacts from the memory, and my phone is also getting slow, could you help me with that also.
Hi soulbachelor, Google Play have an APP called Clean Master which may be the answer to clean your phone caches and junk apps etc. It has good writeups but I haven't used it myself.
With your Contact Deletion problem - there is one thought I had - look in your Call Log to see if you have any contacts in there.
There are many APPS available to Save and Backup your Contacts - but none to Recover them if they are Deleted.
I just found this on Google:http://www.********.com/adr/ I have no idea if it would do what you want, but there are happy users. You would need to use your computer and connect your Ideos U8150 through the USB cable. Neil.
