Help Contact issue
Hazel0017
Hi ok do I had some problems with my location and they told me to do a reset. Ok np. Now my fb contact pics won't show up, not even as a double to join, and I have them all synced. Also I turned the vibration of when typing but it still does it! Can anyone help?
Hi, did you turn of the vibration from the "Language and Input" in settings, if not, go to "Settings", scroll down to "Language and Input", go to "Keyboards and input methods", open "Samsung Keyboard", and if you scroll to the bottom you will see "Key-tap feedback", uncheck "Vibration". Phil
Yes I did thank you I found it hiding in the Swype settings
