Root contacts problem!!!
pswiney3
every time i add a contact to my contacts list it never shows up. so i have to searh for it in my contacts. when i find it i have to export it to my sd card & then import it back to make it appear in my contacts list. when i do this it creates a new file on my sd card of my contacts. how do i delete the contact files that arw on my sd card that i dont need?
***No contact list***
Once I updated to 2.2 from 1.6, my unrooted ZIO worked great, but my contact list only showed a few contacts which I had deleted a long time ago. None of my current contacts showed up.
However, the text messages, all had the names, and you could access the contact's info from the messages, same for the call list. I tried everything to get the list to show, but backup would not add any contacts, as they were clearly somewhere on the phone already. What I wound up doing that worked, was I copied all of my files (including contacts file) from the SD card onto my pc, then formatted the SD. Then I did the factory reset on the phone. Then I recopied the previous SD contents back to the Sd, but only the contact file, music, pics, etc. Nothing that looked like it was for the operations on the phone. Then I brought up the empty contact list on my factory fresh looking phone, and imported the contacts. Finally.
Even Cricket could not help me with this, and just opened a ticket on it. Hope it helps.
