Contacts question
jaj324
On my Note 4 I was able to choose which contacts appeared in my contact list. On the Note 5 I see the option to use a "customized view" but I can't figure out how to choose the groups I want to include! Anyone else having that problem??
Copied from VZW's support page:
Contact Display Options - Samsung Galaxy Note5
http://www.verizonwireless.com/support/knowledge-base-175778/
  1. From a Home screen tap Contacts
    These instructions apply to Standard mode only.
    If unavailable, navigate: Apps > Contacts.
    To display groups, tap GROUPS (located at the top) then select a group.
  2. Tap MORE (located in the upper right).
  3. Tap Settings.
  4. Tap Contacts.
  5. Tap Contacts to display then tap a contact option (e.g., All contacts, Phone, SIM card).
  6. Tap Only contacts with phones to enable or disable.
    Enabled when a check mark is present.
  7. Tap Sort by then select one of the following:
    • First name
    • Last name
  8. Tap Display contacts by then select one of the following:
    • First name first
    • Last name first
