CoPilot Live problems
nicracine
Hello everybody,
Ever since the latest CoPilot Live update, I cannot listen to music while using the application.
As soon as I start the application, the music stops, and won't start back until I close the app.
For now, I use Google Navigate, but I would rather use CoPilot, which I paid for.
Has anybody else has had that problem?
Thanks!
I have found you cannot listen to music while using navigation on copilot, as you won't be able to hear the voice tell you where you are going...
Also SE X10 mini default keyboard does not work on colpilot, installed smart keyboard pro and all sorted!
Best sat-nav app by miles.
Look in the parameters, there is a volume setting that is not related to Android. You can set the volume there for directions, and you will hear the directions well.
It really is the best application, but since I *MUST* have my nusic in the car, it is unusable until they make another software update.
I wish the Android version would let you turn off the Welcome to CoPilot voice message on startup, like you can with the WinMo version!
Rob
