Could not initialize DirectSoundCapture
I still unable to see my hello world , do I need the sounds to see the text ???
Emulator: dsound: Could not initialize DirectSoundCapture
12:06 PM Emulator: dsound: Reason: No sound driver is available for use, or the given GUID is not a valid DirectSound device ID
12:06 PM Emulator: dsound: Attempt to initialize voice without DirectSoundCapture object
12:06 PM Emulator: audio: Failed to create voice `goldfish_audio_in'
12:06 PM Emulator: C:\Users\myname\AppData\Local\Android\Sdk\emulator\qemu\windows-x86_64\qemu-system-x86_64.exe: warning: opening audio input failed
12:06 PM Emulator: audio: Failed to create voice `adc'
12:06 PM Emulator: emulator: WARNING: UpdateCheck: Failure: Error
12:06 PM * daemon not running; starting now at tcp:5037
12:06 PM * daemon started successfully
I using Nexus 5x API 28 , my Android Emulator is 28.0.23
I unable to do Change "Graphics is uneditable
  1. Go to: Tools > Android > AVD Manager
  2. Press the "edit" (pencil) icon next to your AVD
  3. Change "Graphics" to "Software".
Hi Newbie Learn Android,
I have the same problem on my PC, if you still have issue then here is the solution that I have to resolve mine:
1/ for audio output, use a 3.5mm audio plug and insert it into audio out socket, say a headphone or something like that this will activate the onboard audio output.
2/ for audio input(microphone), also use a 3.5mm audio plug(can be a dummy one like audio extention cable) and insert it into the mic-in plug.
now recompile the project and it should work, or at least it works on mine.
Good luck.
