Hey I'm new to the forums, been trying to root and install 4.2.2 on my lg spectrum (running ics 4.0.4) with cm10.1.
I used a thread on this site to root it, everything was going fine. I was following a guide online on how to install cm10.1 and had the files downloaded and on my phones sd card, turned the phone off after unplugging and tried to put it into recovery mode by holding down volume down and power button, which took me to factory hard reset mode. at this screen the guide told me to press power 3 times, so I did and it just erased all my data and didn't take me to clockwork mod as the guide said it should have, because the root I used in that given link said it installed cwm as well as rooting it.
So, I am stuck.
Any help would be appreciated.
Thanks much.
edit: the thread i used was
http://androidforums.com/spectrum-a...20-bootloader-pwnage-tool-lg-spectrum-4g.html
So, I am stuck.
Thanks much.
