Help Could you help me choose the best phone?
  • Start date Start date
Choice?
  • Sony Xperia E4
    Votes: 0 0.0%
  • ZTE Blade A450
    Votes: 0 0.0%
  • Lenovo A536
    Votes: 0 0.0%
  • Total voters
    0
A
Android Question
Guest
Hey. I'm looking to buy either one of these phones http://www.devicespecifications.com/en/comparison/dfbb2b015 I ONLY care about ZTE Blade A450 and Xperia E4. I know they are both cheap and probably low-end phones, but I am not allowed to buy anything over 130 euros. My main uses will be gaming and browsing. Also, is there any possibility that this http://www.gsmarena.com/lenovo_a536-6674.php is better than the other two phones, because I have checked a video where it runs Asphalt 8 very nicely. However, I don't like the fact that it has 2 point multitouch. Thanks.
I'm this guy by the way.
Welcome to the forum :)
Specs alone are only ever part of the story, so it's hard to give a definite answer. The ZTE does have a newer SoC with a more powerful GPU, so if gaming is one of your requirements that would be an argument for considering the ZTE.
Hey, thanks! Do you think the ZTE will be able to run games much better than the Xperia? Also, can you find any downsides with the ZTE? Or maybe some more advantages,
I know very little about these phone, just that on paper the GPU the spec sheet says the ZTE uses is more powerful than the one in the Xperia (the processor cores are also slightly newer, but for serious games the GPU will matter more).
The budget nature really shows up in the screen specs: both are low resolution, but the ZTE is the lower of the two (about the same number of pixels my 2010 HTC Desire had, except spread over a 5" screen rather than a 3.7" one).
The ZTE has a much bigger battery than the Sony too, so ought to have better battery life.
So overall, just going by the specs, it seems the better phone. But specs don't tell you anything about build quality, software, or many aspects of performance (e.g. camera quality, screen quality - specs, such as resolution, don't tell you whether the quality is any good). Having never seen either phone in reality I can't say anything more than what the specs are though.
The only problem is that I can't find how many fingers the phone can detect at once.
