Couple of questions on Android Studio
thkl
Hello,
I have a really important task to do with limitation of time
So, first, where is the code output? I cant find it anywhere, I try to simply sum a bunch of numbers and I see the result nowhere
another question, how do I link two activities/files?
Do I also need an emulator to use android studio? Is this mandatory? Thank you
