Help Couple of questions Please
lennydude
Android Expert
First off..................have always used multi picture live wallpaper to have a different picture for each screen. It does not seem to work in Kit Kat :confused:
Anyone know of a wallpaper app that will work?
On another note...............my screen seems "foggy" and not really sharp. When comparing my S3 and N5 side by side with the same exact picture, the S3 wins every time. Anyone else with this problem?
Do you mean "foggy" as in kind of white or washed out? This is accentuated when you view the phone from a diagonal viewing angle. The nexus doesn't have very good diagonal viewing angles. If you view it straight on, or from a wide vertical or horizontal viewing angle, it should be very clear, but from a diagonal viewing angle, the blacks will wash out. Samsung uses oled screen which are very good at viewing angles and usually have more saturated (some would say less accurate) colors, where as the lcd screen in the nexus will be brighter with truer colors.
