hello,
been using droid for a few months now, for the most part i like it but there are a couple things tha really frustrate me and i can't quite figure them out.
1. dock mode. this ridiculous mode would be great if a couple things happened. a. i could figure out how to edit which icons showed at the bottom. b. if I could disable it without removing it from the doc. but unless i am missing something, clicking the little x does not disable it. i can't figure that out.
2. how to completely, forever get rid of that mode that it flips to after docked for a few minutes. it turns to a black screen with the weather and a couple items i have no interest in. it's not daydram, i can't even figure out what that thing is.
I really want to customize this thing, but for all the great things droid does, it sure seems restricted in some of the most simple things that should be easy. am i wrong?
first, i don't mind the dock mode but there's problem. it docks when i plug it into the dock i have, no sweat, but it also docks when i put it in the mount in the car. just because it's plugged into a charger doesn't mean it's docked. is there a way to make it so it only docks......when it's docked?
second, how can i turn ALL of this stuff off? if i can't figure out how to make it work the way i want, i would just rather turn it off completely but i can't find anywhere that i can stop it from going into dock mode. is that even possible?
sorry if i sound frustrated, these things are so basic and simple yet not easy to do, and i can't figure out why
