Help CPU Cores vs Battery Drain
blksith0
In general, when comparing the silly numbers of cores phones have now, does a 12-core drain battery 3x faster than a 4-core would?
Is there a trend towards more battery drain on phones with more cores?
It seems like you have no choice but to get 8+ cores nowadays.
The simple answer is no, a 12-core CPU doesn't drain 3x more battery than a 4-core.
It depends a lot on the OS and software in term of power efficiency. The OS shouldn't let an app use all the cores at the same time unless absolutely necessary.
In long term a 12-core could be more power efficient than a dual or quad core. For example if the 12-core CPU can finish a heavy task in 15 seconds, it should consume less battery than a 4-core that takes a whole minute to finish the same task.
Also, that's not how these CPU are designed. Octacores for example aren't using all 8 cores at once. Octacores use 4 high speed cores and 4 low speed power efficient cores. It uses the 4 power efficient cores most of the time, but switches to the higher speed cores as needed for power intensive tasks (That's a really simplified explanation). Basically that's part of the reason why the Samsung S7 with the quad core Snapdragon 820 has almost the same performance as an S7 with the octacore Exynos, but the Exynos having better battery life.
My phone has an octa-core CPU, I used an app called multi-core observer that can display CPU load in real time, but I rarely see the CPU using more than 6 cores at a given time. The majority of apps including some big games usually take 4 cores.
Marketing departments like to latch on to a single number (clock speed, number of megapixels, etc) and use this to promote a "bigger = better" message. It's never as simple as that in reality, but simplistic messages sell better than complicated truths, and I'm afraid "core counting" has been one of these things in recent years.
The biggest truth that the "number of cores" metric hides is that not all cores are equal, indeed different cores can be very different in processing power, energy consumption or both. The next is that how the firmware and OS use the cores makes a huge difference (e.g. how efficiently tasks are allocated to cores, when cores are shut down), so different SoCs using the same core architecture and same number of cores need not be equivalent. But as said above, a properly-designed chipset+firmware will shut down cores when they are not needed, so they don't automatically result in greater power drain when not in use.
The real trend in recent years has been towards phones that idle efficiently but will use power heavily when pushed, so the variation in battery life with usage gets wider.
And this year it's perfectly possible to buy "mere" 4 core phones: Qualcomm's Snapdragon 820, used by almost all flagships this year, is a quad-core SoC (4 cores of the same architecture, but 2 with a higher maximum clock speed than the other 2).
