Hi Everyone,
I want to use eclipse for this purpose. What are the steps to create Android project from minimum number of existing files? Is is possible to generate Android project only from Activity.java file if not then which minimum number of files are needed and what should be there hierarchy in the existing folder.
Thanking in anticipation for kind replys
