First of all it seems like you've ****ed something up, so yeah. Second wrong section. There's a section for the Huawei Ascend. And third, try a factory reset and dial *228. Battery life on this phone isn't good if you constantly keep the screen on. On most Android phones it will dye within a few hours if you have a lot of apps running and keep the screen on. Multitasking kills the battery. Try an app killer. If you're dumb don't get a smartphone. Best suggestion I could give you.
