cjreyes666
Original Post:
http://forum.xda-developers.com/showthread.php?t=2106830
*FOLLOW ALL INSTALLATION INSTRUCTIONS THOROUGHLY - OR THE INSTALLER WILL FREEZE*
THE INSTALLER MAY FREEZE ANYWAYS - THIS IS SAID TO BE NORMAL. JUST PULL BATTERY, RE-WIPE AND TRY RE-FLASHING. (SHOULDN'T TAKE TOO MANY ATTEMPTS) BUT IF YOU WIPE THOROUGHLY IT SHOULD GO SMOOTHLY.
!!!THIS IS NOT​ MY WORK!!!
Quick run down (More Info/Download In Header Link)
Runs and Installs on all major US Galaxy S3 phones
Full Multiwindow Enabled for all apps
Galaxy S4 themed Multiwindow theme and tab
Hyperdrive Control
HyperdriveOTA
Custom Rom Settings
Home Button Lag Hack w/ working double tap
-Double tap for Google Now or S4 S-Voice
Volume Rocker Music Skip Track for ALL music Players
MMS app extended settings
-Scheduled Messaging, Group messaging,. Screen on/off messaging toggle
-Message vibration and Signature options
-Save/Restore Messages
-SMS 1000 recipient limit enabled
-SMS limit per hour increased
Custom Hyperdrive 4-Way Boot Menu
Note 2 Extended Camera Settings
-Use Camera with low battery
-Use Camera while on a call
-Zoom with Volume Keys
-Toggle for sound on/off
-HDR Camera
-Higher Video and audio bit rate in camcorder
Browser Extended Settings
Galaxy Note 2 Features:
- Gallery application
- Paper Artist
- Page Buddy
- Popup browser
- S Note (in HyperdriveOTA)
- S Memo
- S Planner
- Shutdown Animation
- Torch Widget
- Weather widgets
Unlocked VZW Wifi Tethering
Custom Font Choice (300 to choose)
Custom Hyperdrive Wallpaper Chooser
Enabled Additional Rom Languages
Sony Bravia Engine
360 degree rotation throughout
Removed ongoing notifications and annoying icons
Muted Boot and Shutdown Sounds
Fixes for OTG wakelock and Media Scanner drain
Additional Live Wallpapers
Device Status reads as Normal
Lockscreen Home doesn't close current app
Removed all Verizon Branding and Bloat
Full Galaxy S4 Feature Set
"Download Center" - be sure you know what you're doing if going straight to this.
(From Second Post on First Linked Thread)
xda-developers - View Single Post - ★[ROM][4.1.2][5/14] Hyperdrive RLS13 ║ ★ Unsurpassed Customization and Quality ★ ║
Read more: [ROM-LINK][4.1.2][5/14] Hyperdrive RLS13 ║[AROMA][MULTIWINDOW]
Hyperdrive Control
HyperdriveOTA
Custom Rom Settings
-HDR Camera
- Paper Artist
- Page Buddy
- Popup browser
- S Memo
- S Planner
- Torch Widget
- Weather widgets
Sony Bravia Engine
