[critcal help] i delete my phone system
hi please help me
i have a big problem in my Note 4 Samsung SM-N910C
i was rooting my phone by twrp... after some time i wanna delete root so i enter mY twrp then suddenly
wipe all
1-cach
2- Dalvik cach
3- System
4- Data
5-Internal storgae
6-Micro Sdcard
so i delete the phone system so it is not work again stuck only on twrp and when i try to install N910CXXU1COH4_N910COXA1COH4_N910CXXU1COH4_HOME.zip from sdcard it failed
and when i tried to install from Odin 10 N910CXXU1COH4_N910COXA1COH4_N910CXXU1COH4_HOME.tar.MD5
give me failed
<ID:0/003> Added!!
<ID:0/003> Odin engine v(ID:3.1005)..
<ID:0/003> File analysis..
<ID:0/003> SetupConnection..
<ID:0/003> Initialzation..
<ID:0/003> Get PIT for mapping..
<ID:0/003> Firmware update start..
<ID:0/003> SingleDownload.
<ID:0/003> sboot.bin
<ID:0/003> NAND Write Start!!
<ID:0/003> FAIL!
<ID:0/003>
<ID:0/003> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
so please how to fix it
My phone stuck only on Samsung note 4
If you wiped system, that's why your phone has no idea what to do. You wiped away the operating system of the phone. Now it's waiting for instructions. You have to get the stock firmware for the phone onto external memory, and then use TWRP to flash it. Otherwise, find a good custom ROM. If you have tried that and failed, you might have to send the phone to Samsung for a reflash... and that will not be cheap.
Going forward, NEVER wipe ANYTHING without making a valid backup first! If you inadvertently delete the wrong thing, you can always restore the backup and it will be like nothing ever happened. Good luck.
No need. The same went with my phone .... just the boot loader of my stock was older ... I just downloaded a newer version [emoji1]
