Help CS918 Rom Problems
mrpunch27
I have a CS918 Android TV box that froze and would not recover.
The manufacturer of the board is szzxsd and after some effort I finally tracked down two different ROMs that should work for this board.
I have flashed both of them using the RKbatch tool and they both work and run all my apps well but I can on;y boot the box a SINGLE time.
The problem occurs after the device is shut down or power failure. It won't boot again and there is no output to the TV through either HDMI or composite video. I'm tearing my hair out because it seems the device works hardware-wise but something is corrupt somewhere.
Any advice on how I can fix this?
Thanks
