Cubot X18 Plus Review! Hmm not bad...
zijincheng
Cubot X18 Plus Review! Cubot did a pretty good job but its fairly expensive.
Cubot X18 Plus Specifications:
Mediatek MTK6750T Octacore Processor
6” 18:9 2160x1080 LCD
4GB RAM, 64GB ROM
Android 8.0 Oreo
4000mAh Battery
178g, 15.85 x 7.36 x 0.85 cm
i think nowhere. but this is the same with almost all other chinese smartphones company.
only ZTE, Huawei and similar have much better support.
'when' and not 'if'
That doesn't sound like much confidence in it to me.
When you buy for example on Gearbest, and if the phone became faulty. then in mostly cases you need to send back to China.
but if you buy it from your local IT shop, then for sure is diferent.
