Help current location not updating
Hey there, my current location updating is being a bit unpredictable. If I'm travelling about different towns my location will update but if I stay in one place for a day or two then the next time I travel It won't update without me having to restart my phone a couple times. It's small and not really a problem but its been bugging me. I have GPS, WiFi and network data on at all times so I don't think it's anything to do with that and if I go onto facebook and post it'll detect the new location but the clock/weather widget won't.
Any one else have or seen this problem and know of any fixes?
Thanks.
Don't know if this will help you out try checking out your apps make sure you have certain apps turned onn. Because I am using the att one x not sure which one you are using the international one x or the quard core one x. But some apps work in conjunction with other apps.A friend has the internation one x and he had to turn back on his map app with his gps as well as other apps.so i don't know if his will help you but check the apps.
