Curved Edge Glass Screen Protector for Pixel 2XL
delpi767
Has anyone found a screen protector for the Pixel 2 XL that is curved on the edges to match the profile of the phone?
The only ones I see on Amazon are cut short to avoid the curved edges.
I just got it today and installed it. It is awesomeness at its best. I strongly recommended. Your fingers just slide through the screen without any pressure and it is as sensitive it's not better than without it. I am ready happy with it
No because the way you have to set it up is different yet detail.I taught it is going to be different but once you follow the instructions it comes it perfect
Cool, thanks! I saw those issues mentioned in a few of the reviews I read so was curious about your experience. I may have to go this route for my Pixel 2.
Update: installed one on my Pixel 2. Very happy so far. I love the way the jig got the glass perfectly centered on the screen. This is by far the most precise install I've ever had.
Thanks for the recommendation, @wvargas67!
