Apps Custom Camera takes low quality pictures
S12
I have a custom camera and it takes really low quality pictures. I need help to fix this.
Code:
import android.content.Context;
import android.content.pm.PackageManager;
import android.hardware.Camera;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.SurfaceView;
import android.view.WindowManager;
import android.widget.Button;
import android.widget.FrameLayout;
import android.widget.ImageButton;
import android.widget.LinearLayout;
import android.widget.RelativeLayout;
import android.widget.Toast;
import java.io.File;
import java.text.SimpleDateFormat;
import java.util.Date;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.IOException;
import android.hardware.Camera.PictureCallback;
import android.view.View;
import android.view.View.OnClickListener;
public class MainActivity extends AppCompatActivity {
    private Camera mCamera;
    private CameraPreview mPreview;
    private Camera.PictureCallback mPicture;
    private Button switchCamera;
    private Context myContext;
    private FrameLayout cameraPreview;
    private boolean cameraFront = false;
    @Override
        setContentView(R.layout.activity_main);
        getWindow().addFlags(WindowManager.LayoutParams.FLAG_KEEP_SCREEN_ON);
        myContext = this;
        initialize();
    private int findFrontFacingCamera() {
        int cameraId = -1;
        // Search for the front facing camera
        int numberOfCameras = Camera.getNumberOfCameras();
        for (int i = 0; i < numberOfCameras; i++) {
            Camera.CameraInfo info = new Camera.CameraInfo();
            Camera.getCameraInfo(i, info);
            if (info.facing == Camera.CameraInfo.CAMERA_FACING_FRONT) {
                cameraId = i;
                cameraFront = true;
                break;
        return cameraId;
    private int findBackFacingCamera() {
        int cameraId = -1;
        //Search for the back facing camera
        //get the number of cameras
        //for every camera check
            if (info.facing == Camera.CameraInfo.CAMERA_FACING_BACK) {
                cameraId = i;
                break;
        return cameraId;
    public void onResume() {
        super.onResume();
        if (!hasCamera(myContext)) {
            Toast toast = Toast.makeText(myContext, "Sorry, your phone does not have a camera!", Toast.LENGTH_LONG);
            toast.show();
            finish();
        if (mCamera == null) {
            //if the front facing camera does not exist
            if (findFrontFacingCamera() < 0) {
                Toast.makeText(this, "No front facing camera found.", Toast.LENGTH_LONG).show();
                switchCamera.setVisibility(View.GONE);
            mCamera = Camera.open(findBackFacingCamera());
            mPicture = getPictureCallback();
            mPreview.refreshCamera(mCamera);
    public void initialize() {
        mPreview = new CameraPreview(myContext, mCamera);
        cameraPreview = (FrameLayout) findViewById(R.id.camera_preview);
        cameraPreview.addView(mPreview);
        ImageButton capture = (ImageButton) findViewById(R.id.button_capture);
        capture.setOnClickListener(captrureListener);
        switchCamera = (Button) findViewById(R.id.button_ChangeCamera);
        switchCamera.setOnClickListener(switchCameraListener);
    OnClickListener switchCameraListener = new OnClickListener() {
        @Override
        public void onClick(View v) {
            int camerasNumber = Camera.getNumberOfCameras();
            if (camerasNumber > 1) {
                //release the old camera instance
                //switch camera, from the front and the back and vice versa
                releaseCamera();
                chooseCamera();
            } else {
                Toast toast = Toast.makeText(myContext, "Sorry, your phone has only one camera!", Toast.LENGTH_LONG);
                toast.show();
    public void chooseCamera() {
        //if the camera preview is the front
        if (cameraFront) {
            int cameraId = findBackFacingCamera();
            if (cameraId >= 0) {
                //open the backFacingCamera
                //set a picture callback
                //refresh the preview
                mCamera = Camera.open(cameraId);
        } else {
            int cameraId = findFrontFacingCamera();
    @Override
    protected void onPause() {
        super.onPause();
        //when on Pause, release camera in order to be used from other applications
        releaseCamera();
    private boolean hasCamera(Context context) {
        //check if the device has camera
        if (context.getPackageManager().hasSystemFeature(PackageManager.FEATURE_CAMERA)) {
            return true;
        } else {
            return false;
    private PictureCallback getPictureCallback() {
        PictureCallback picture = new PictureCallback() {
            @Override
            public void onPictureTaken(byte[] data, Camera camera) {
                //make a new picture file
                File pictureFile = getOutputMediaFile();
                if (pictureFile == null) {
                    return;
                try {
                    //write the file
                    FileOutputStream fos = new FileOutputStream(pictureFile);
                    fos.write(data);
                    fos.close();
                    Toast toast = Toast.makeText(myContext, "Picture saved: " + pictureFile.getName(), Toast.LENGTH_LONG);
                    toast.show();
                } catch (FileNotFoundException e) {
                } catch (IOException e) {
                //refresh camera to continue preview
        return picture;
    OnClickListener captrureListener = new OnClickListener() {
        @Override
            mCamera.takePicture(null, null, mPicture);
    //make picture and save to a folder
    private static File getOutputMediaFile() {
        //make a new file directory inside the "sdcard" folder
        File mediaStorageDir = new File("/sdcard/", "JCG Camera");
        //if this "JCGCamera folder does not exist
        if (!mediaStorageDir.exists()) {
            //if you cannot make this folder return
            if (!mediaStorageDir.mkdirs()) {
                return null;
        //take the current timeStamp
        String timeStamp = new SimpleDateFormat("yyyyMMdd_HHmmss").format(new Date());
        File mediaFile;
        //and make a media file:
        mediaFile = new File(mediaStorageDir.getPath() + File.separator + "IMG_" + timeStamp + ".jpg");
        return mediaFile;
    private void releaseCamera() {
        // stop and release camera
        if (mCamera != null) {
            mCamera.release();
            mCamera = null;
Do you want it to take higher quality pictures? From what I gathered the camera is going to take the best quality that it can. Can you compare the quality of the apps picture vs the same pic taken by the built in os?
yes I want it to take higher quality photos. its wayyy low res compared to the system camera. I feel the app is not using the full advantage of the phone camera. otherwise not using all the MegaPixels.
