This is just a link to his kernel for those who are on AOKP. He also have a sound mod for better audio quality. He stuff is high quality and stable so give it a try and you will never regret it.
All his kernels for download https://www.androidfilehost.com/?w=files&flid=33532
Stay up to date with his work on this device on XDA
http://forum.xda-developers.com/general/help/discussion-galaxy-avant-t2845229/page163#post61406423
I tested it out and wow its pretty good. It has does well with the RAM and Greenify I average over 850 MB of free ram with everything cleared. Battery life seem pretty good both screen off and on (still testing) and The performance has been liquid smooth very good balance of performance and battery. I love the other amazing features it has like changing the RGB, Intelliplug settings, governors/I/O schedulers are turnable, and Volume Gains (DBs) I used this app that allows me to changed all these values and more for FREE called Kernel Aduitor. Thank you and keep up the good work
UPDATE (07/05/15): To fix camera not recording videos go to your build.prop and delete tge line that says: qcom.hw.aac.encoding=true use "build.prop editor" in the play store if you don't know how to do it manually.
I found a great way to save battery during standby. I get much better usage on one charge as a result. Make sure you download the latest kernel (6/18) for AOKP and get an app that can change kernel settings like trickstermod. But I personally use Kernel Adiutor to do this. Go to CPU Hotplug and scroll down to CPU Maximum Screen Off Frequency and change it to 600 mhz and it will lessen battery drain on standby. It won't affect your lockscreen/turning back on phone push notifications nor music when you turn the screen off while playing. I tried to go lower back it won't really stick but its all good though!!!
Enjoy ALL credit goes to aznrice2k4
