Custom Hero Rom on Magic 32a problem
junooni
Alright! so just like alot of other androidians I rooted my magic 32a(Rogers) & uploaded a hero custom rom on my magic 32a(Rogers). It worked pretty smooth & I was very happy with it untill i realized that Im unable to send/Recv emails on 3g & the gps didnt worked as well. So i started paniking & went in the recovery mode again & wiped the data & formated the sd card using fat32+swap.
Well then i rebooted & now its stuck on thehero screen & keep on repeating the boot screen & its stuck on tha same screen. I tried framatting it like 5 times but no luck. So now Im crying out loud for help....please some one, anyone, ?????
First of all you need 3 partitions on your sd card. Fat32+Swap+EXT3.
You need to do a wipe, then wipe ext3, then flash the rom and reboot.
Thanx alot man....
ok now can u tell me a hero rom for my magic 32(Rogers) whish works perfectly fine.. i mean 3g, gps, & eery thing works on it??
Thanx alot man....
amon_ra latest 1.6 donut works flawlessly on my rogers/32a magic. It doesnt have sensui, but the new google nav works on it after some tinkering
