Hey everyone, I'm a little stuck right now. i'm getting some funky errors when I try run my project.
Basically what it's doing is pulling a number of entries from a DB and displaying them in a custom ListAdaptor.
I'm getting "ArrayAdapter requires the resource ID to be a TextView" as a error
Here's where the Listview is populated
______________________________
public View getView(int position, View convertView, ViewGroup parent) {
View v = convertView;
if (v == null) {
LayoutInflater vi = (LayoutInflater)context.getSystemService(Context.LAYOUT_INFLATER_SERVICE);
v = vi.inflate(R.layout.status_container_list_entry, null);
JobListAdaptor o = items.get(position);
if (o != null) {
TextView tt = (TextView) v.findViewById(R.id.toptext);
TextView mt = (TextView) v.findViewById(R.id.middletext);
TextView bt = (TextView) v.findViewById(R.id.bottomtext);
//TextView st = (TextView) v.findViewById(R.id.sidetext);
if (tt != null) {
tt.setText("Name: "+ o.getName());
if(mt != null){
mt.setText("Provider: "+ o.getProvider());
if(bt != null){
bt.setText("Most Recent Feed Date: "+ o.getMostRecentFeedDate());
//if(st != null){
// st.setText("Status: "+ o.getStatus());
return v;
Here's the XML display
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android:layout_width="fill_parent"
android:layout_height="?android:attr/listPreferredItemHeight"
android
adding="6dip">
<ImageView
android:id="@+id/icon"
android:layout_width="wrap_content"
android:layout_height="fill_parent"
android:layout_marginRight="6dip"
android:src="@drawable/icon" />
<LinearLayout
android
rientation="vertical"
android:layout_width="0dip"
android:layout_weight="1"
android:layout_height="fill_parent">
<TextView
android:id="@+id/toptext"
android:layout_height="0dip"
android:gravity="center_vertical"
<TextView
android:id="@+id/middletext"
android:singleLine="true"
android:ellipsize="marquee"
<TextView
android:id="@+id/bottomtext"
<TextView
android:id="@+id/sidetext"
</LinearLayout>
</LinearLayout>
And where's its called in my Home Activity
private void showStatusItems(List<StatusContainer> list)
_loginLayout.setVisibility(View.INVISIBLE);
_mainLayout.setVisibility(View.VISIBLE);
ArrayAdapter<JobListAdaptor> listAdapter = new ArrayAdapter<JobListAdaptor>(this, R.layout.status_container_list_entry, StatusContainer.getStatusItemList());
_statusContainerListView.clearChoices();
_statusContainerListView.setAdapter(listAdapter);
Any help or tips would be greatly appreciated..
if (v == null) {
if (o != null) {
if (tt != null) {
if(mt != null){
if(bt != null){
//if(st != null){
return v;
android
<ImageView
<LinearLayout
android
<TextView
<TextView
<TextView
<TextView
</LinearLayout>
</LinearLayout>
