Help custom ringtones wont play when i recieve calls on s3
I downloaded gtunes and used it to make ringtones and set them as default but when I get a call no sound plays it only vibrates . I've also tried making them with another app called ringtone maker pro but still no sound . Thanks for any help
So can anyone help? I've noticed that uf I do the entire song by long press and set as it works but not if I edit the song to be shorter
Haven't used that app specifically.
Please download zedge and download and apply ANY ringtone. If it works, it rules out generic "custom" tones and points directly to your app
i use tonepicker and ringtone maker pro. you can set a song as a ringtone or text or email notifcation and if you want a certain part of a song use ringtone maker cut it down to size.
ric
I've used ringdroid in the past, before I got zedge. Worked great.
Ringdroid doesn't work on ICS yet. It was one of the first downloads I went for when I upgraded from my S1 Vibrant... I found a free program called Ringtone Maker which is almost identical to Ringdroid, and it works just fine.
MP3 ring tone maker works really well for me, let's you search for music online or uses files stored locally on the phone.
