Customize notification sounds
mrburt
Hello,
I want to change the sound that my phone makes when it turns on and off, when the sd card mounts, text message, voicemail, phone call, low memory etc to all different custome sounds. I know how to do the e-mail, text, voicemail and phone calls. but thats where it ends.
I was wondering if there was an app out there that would extend the sounds options
any help would be appreciated
Thank you,
Burt
You can change everything but the startup sound. You dont need an app to do it, just put your sounds/mp3 on your SD card in a folder called Media, then another folder called Notifications. So you have SD/Media/Notifications/yourfile.mp3
I've gotten that far, my main thing right now is making it so the sd card notification, voicemail notification, low memory notification, shut down and start notifications are all different.
Thanks for the quick reply!
-Burt
