Sorry for a relatively newbie question, but are CWM and TWRP mutually exclusive? In other words, if you have CWM installed, and then you install TWRP, can you get back into CWM without "uninstalling" TWRP? And if you installed TWRP last, would you need to re-install CWM or would it be sufficient to just delete the TWRP folder from your device? I assume whichever recovery was installed last will overwrite the previous version, but I'm not positive how it works. Any insight would be appreciated...
