Scur
Android Expert
So dragonzkiller got CM9 working (mostly) for the X2 the other day. That is all.
***NEW*** Google Play installs larger apps to the SD card on installation. After a reboot these no longer appear in the apps drawer. A workaround is to install the app, go to "Settings > Apps" and click on the app. Once there click "Move to phone" and you're app should remain persistent across reboots.
MUIUI 4, second ICS ROM, is on xda now. Based on CM9, so all the same issues. I'm trying it out in a bit.
sorry to hear you are having so much problems with it. If you can get into BSR try wiping cache/dalvik cache see if it helps. It looks promising but there's something about MIUI that I have not liked since the first release. Hopefully the next release will be better. For the mean time I'm back on CM7 till the next CM9 Alpha or RC.
Funny you said you had problems with the BSR, I had problems going back to CM7 as well. I SBF'ed back to 2.3.4, then rooted and installed the patched BSR but I couldn't get it to go into recovery. I ended up using the previous version of BSR, then installing CM7 and then installing the patched BSR.
I installed the CM9,the gapps and the MX2 wifi patch. Everything works great so far except I have no wifi. I downloaded a couple of apps and widgits to turn wifi on/off but no luck. At a loss of what to do next to fix this. Should I have ran the MX2 wifi patch for the droid X2? What should I try next?
