Help CyanogenMod Update problems - no data
hinky
Here is a word of warning to anyone using CyanogenMod. The latest release that they push as a standard update caused the phones my family have to lose their ability to connect to the data SIM and they have no data among numerous other issues. I wonder if anyone has some advice on what can be done to fix other than flashing the entire phone which will not only take several hours but also is just not going to happen easily with people who don't even know what flashing a ROM is (like most phone owners.) Right now Cyanogen is working on it but you are probably best served knowing and questioning whether you should update. I hear that Oppo is almost done with their Android version and they all plan to leave CyanogenMod and use the company's Android. Just makes things easier, support, reliability, etc but I think it's not quite there yet.
Hinky,
What is your carrier/network provider?
My advice is to firstly try and edit your carrier APN settings so that the 3G/4G data starts working again before you start flashing entire ROM on your phone again.
The below video demonstrates how to do this:
