I have a brand new Moto X, and when I called Consumer Cellular to activate it, the tech support person said she'd never been able to get a Moto X to work with CC's data network. Not encouraging, but I find it hard to believe that there are no Moto X users out there using Consumer Cellular. I found a post on a different forum and tried the settings there, with no luck.
Please, can someone tell me where I'm going wrong? I have the checkbox checked next to "Data enabled: Enable data access over Mobile network". Is there any other setting that needs to be set a certain way?
Also, every time I change the settings for the ConsumerCellular APN under Access Point Names, I touch "Save". I then power my phone down, and immediately power it back up. Is that the correct process?
Does anyone have APN settings that work for a Moto X on Consumer Cellular? Any help or suggestions would be greatly appreciated!
These are the settings I've tried already:
APN: att.mvno
Proxy : 66.209.11.32
Port: 80
Username: <Not set>
Password: <Not set>
Server: <Not set>
MMSC: http://mmsc.cingular.com
MMS proxy: 66.209.11.32
MMS port: 80
MCC: 310
MNC: 410
Authentication type: PAP
APN type: default
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: None
APN: att.mvno
Port: 80
Username: <Not set>
Password: <Not set>
Server: http://mmsc.cingular.com
MMS port: 80
MCC: 310
MNC: 410
APN type: default,mms,supl,agps,fota
APN protocol: IPv4
Bearer: Unspecified
MVNO type: None
APN: att.mvno
Proxy: proxy.mvno.ccmobileweb.com
Port: 80
Username: Not set
Password: Not set
MMS port: Not set
MCC: 310
MNC: 410
Authentication type: PAP or CHAP
APN type: Not set
APN protocol: IPv4
Bearer: unspecified
MVNO type: none
Finally, these are the settings that the CC tech support rep had me try (after telling me they hadn't worked for any Moto X user, sigh):
APN: att.mvno
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: http://mmsc.cingular.comhttp://mmsc.cingular.com
MMS proxy: proxy.mvno.ccmobileweb.com
MMS port: 80
MCC: 310
MNC: 410
APN type: internet,mms
APN protocol: IPv4
Bearer: unspecified
MVNO type: none
APN: att.mvno
Port: 80
Username: <Not set>
Password: <Not set>
Server: <Not set>
MMS port: 80
MCC: 310
MNC: 410
APN type: default
APN protocol: IPv4
Bearer: Unspecified
MVNO type: None
APN: att.mvno
Port: 80
Username: <Not set>
Password: <Not set>
MMS port: 80
MCC: 310
MNC: 410
APN protocol: IPv4
Bearer: Unspecified
MVNO type: None
APN: att.mvno
Port: 80
Username: Not set
Password: Not set
MMS port: Not set
MCC: 310
MNC: 410
APN type: Not set
APN protocol: IPv4
Bearer: unspecified
MVNO type: none
APN: att.mvno
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 310
MNC: 410
APN protocol: IPv4
Bearer: unspecified
MVNO type: none
