Apps data between two class
Hi, I know to load data from WebService o load other resource i need to creare a separate Thread. Ok i tryed and i't ok but all example show Thread inside the class but i'd like create a system of message between class, a second class load and parse data adn after sen data to firt class.
Sorry for mybad english, there is the code
package com.example;
import android.app.Activity;
import android.os.Bundle;
Code:
public class MainClass extends Activity {
    private UtilClass u_load;
	/** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
        setContentView(R.layout.main);
        u_load= new UtilClass();
        u_load.loadData("http://www.mysite.com/data.xml");
Code:
public class UtilClass {
	public UtilClass() {
		// TODO Auto-generated constructor stub
	void loadData(String path){
		Thread t = new Thread() {
            public void run() {
                mResults = doSomethingExpensive();
                mHandler.post(mUpdateResults);
        t.start();
I would have the task of loading data is given to the second class and after send data to MainClass. I don't want create UtilClass as Activity
Well... You've already got it almost all the way there. The easiest understandable way to do it, is to give your UtilClass a reference to the caller in either its constructor like this:
Code:
public UtilClass(MainClass main){
or in the method you call to do the heavy lifting like this:
Code:
public void loadData(MainClass main){
Then you can define some public method in the MainClass which your UtilClass can call (in my example by calling main.somePublicMethod() ) whenever it is done crunching data.
