Help Data Roaming and Data Traffic
DomtaR
With the 2.1 upgrade, I have a little question about mobile network settings.
I do not have 3G and do not have a monthly data plan. In 1.6, all I had to do was tick off "data roaming" in the Mobile Network Settings to make sure I do not ever connect to the 3G network.
In 2.1, there are "Data Roaming" and "Data Traffic". If I were to tick off "Data Roaming", would that mean that the "Data Traffic" is no longer in use either, even if its ticked on? I do not want to tick off the "Data Traffic" option because it leaves a huge ugly picture on the notification bar =/
Any help would be greatly appreciated, as I do not want an abundance phone bill due to this!
Just tick off Data Traffic and that will stop all data transmissions. Data Roaming was turned off by default on my phone while Data Traffic was turned on by default after the update. Hope this helps!
make sure that data traffic is disabled, this is turn off data.
and disable data roaming if you dont want to get charged for using your phone while out of your country.
In conclusion disable both if you dont want a nice big bill.
So, what is data traffic?
Is this emails, sms, etc.? If so then if you disable this these will not come through automatically?
Thank you
Thank you
Data traffic is MMS (picture messages) and any other data transmission that requires an internet connection (e.g., email) . SMS goes through the regular phone connection so you don't need a data connection for that.
So, if I disable data trafic, I cant go internet with out using wi-fi. That means internet will not open even accidently. But if I disable it, can I send text messages and normal calls? Thanks
Want to do it the easy way? Download from the market "SwitchPro widget"
The ugly icon you see in the notification bar is data disabled via mobile network, that stops all data to/from the phone which is not what you want. You just want to ensure you don't connect to 3g. The easy way to do it is to run SwitchPro, it has a "toggle" for "data connection" simply press the "toggle" to activate or deactivate it....will not give you the icon in your notification bar unless ur connected to 3g network. But when you turn it off, no icon. Another thing you could/should do too is turn off "background data" when you don't want apps to sync/send/receive data....do that by going into settings/accounts & sync and untick the background data box.
Yup.
SMS messages aren't data....they are separate from that. You don't need data or wifi on to receive txts.
If you want to receive txts with pics....that requires data.....but no one actually does those.
Yup.
No one sends MMS messgs? That's a first
