Help DatePicker Dialog issue
jeyshree
Hello Responsible,
I am doing an Android Developement and i have a doubt in datebpicker dialog.
When a button is clicked,a date picker pops up and user should be able to select the date.
Below is the code written
Java:
package com.example.jeyshree.datedialog;
import android.app.DatePickerDialog;
import android.app.Dialog;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.DatePicker;
import android.widget.Toast;
public class MainActivity extends AppCompatActivity {
    Button B1;
    int day_x, month_x, year_x;
    static  final int id=0;
    @Override
        setContentView(R.layout.activity_main);
        B1 = (Button)findViewById(R.id.button);
        B1.setOnClickListener(new View.OnClickListener()
            @Override
            public void onClick(View v) {
                showDialog(id);
    @Override
    protected Dialog onCreateDialog(int id1)
        if (id1==id)
            return new DatePickerDialog(MainActivity.this,listener,year_x,month_x,day_x);
        return null;
    protected DatePickerDialog.OnDateSetListener listener
            =new DatePickerDialog.OnDateSetListener()
        public void onDateSet(DatePicker view,int year,int month,int day)
            year_x=year;
            month_x=month;
            day_x=day;
            Toast.makeText(MainActivity.this,Integer.toString(day_x)+":"+Integer.toString(month_x)+":"+
                    Integer.toString(year_x),Toast.LENGTH_SHORT).show();
The code is successfully compiled and when i click a button,the dialog pops as shown in image 1.But i want date picker as image 2
Please let me know where do i have to change the code.
Thanks in advance
You need to set spinner style for your Datepicker dialog. In the XML layout use this
Code:
<DatePicker
 android:id="@+id/datePicker"
 style="@style/MyDatePickerStyle"
 android:theme="@style/MyDatePickerSpinnerStyle"
And you may want to apply this style to prevent the calendar from being shown
Code:
<style name="MyDatePickerSpinnerStyle" parent="@android:style/Widget.Material.DatePicker">
<item name="android:datePickerMode">spinner</item>
 <item name="android:calendarViewShown">false</item>
 <item name="colorControlNormal">#d50000</item>
</style>
Source: http://www.zoftino.com/android-datepicker-example
