I picked up my New Verizon Note 4 today and it's my first Note. it fully loaded with tons of useless preinstalled apps. Is there a quick way to get rid of all of them. Thanks in advance
Unless you root your device.. no you can't get rid of them. You can however go to the app info for each app and uninstall the updates then turn them off.. That will get them to their smallest possible size and remove them from your app drawer
