Debug usb mode probleme help me please !
dada97215
Hi David,
I need an infotmation about usb debug mode. During a test on my device
(htc dream) something went wrong, so I need to access with adb
from the recovery mode (I use a custom reecovery of Drakaz), but the
debug mode is not enabled in my device and I can't access to the
system due to a start up problem...
There is a way to enable usb debug mode from terminal or phisically?
(I can only work with fastboot at the moment...)
Thank you in advance:mad:
ADB works only in debugging mode, most of us ignore while trying to use it that it stands for Android Debug Bridge. Fastboot usally works in download Mode.
When phone boots normally it connects to ADB if sdk installed, drivers loaded for subject device, and fastboot connects in download / recovery only.
one can easily check using command adb devices / fastboot devices to know which mode you are in. Hope this helps.( please check path as in recent updaes of SDK adb has moved to platform-tools folder.
