A
Android Question
Guest
Hello everyone,
I'm using Android 4.0, and I used to be able to edit the default General Audio Profile settings myself (for example, the volume, the SMS sounds etc.) but after I restored to factory defaults, I seem unable to do that again.
Also, how can I turn off the vibration after every time I return one screen back? I had it turned off somehow prior to the restoring settings, cannot find again how to return it to non-vibration.
Thank you!
Thank you!
