I'm using Launcher Pro and just yesterday I started having the issue where if you long-press Home and switch apps, you remove your default launch choice and then need to reselect it the next time you short-press on Home. It remembers the setting until I again long-press and use the app switcher.
My question: how do I get this to stick? What 'app' is used to do the app switch by default, and is there anything else I could use to do this? I would hate to be stuck with this permanently, and I'm not thinking it is LauncherPro's fault. What other apps could conflict and cause this behavior?
Thanks in advance!
Thanks in advance!
