Default sounds
Can anybody please tell me how to get my default sounds back on my S3. When I go into the main menu and sounds it only shows files from zedge & es file explorer
Thanks
Default sounds as in like rings and notification sounds?
Well you can just turn up your volume?
Otherwise go into Settings > Sounds and choose what you want your ringtone and default notification sound to be...
Other sounds might have to be chosen via the App Settings.
