Delete and Edit methods in ListView
Meugiwara
Hello !
I'm developing a "ToDoList" and I'm reaching some problems. I want to add some "features" like : delete, edit and add a description to each task. So, my code is like this :
Java:
public class MainActivity extends AppCompatActivity {
    private ArrayAdapter<String> itemsAdapter;
    private ArrayList<String> items;
    private ImageButton formButton;
    private ListView lvMain;
    @Override
        setContentView(R.layout.activity_main);
        commonFunction();
    public void commonFunction() {
        lvMain = (ListView) findViewById(R.id.lvMain);
        items = new ArrayList<String>();
        readItems();
        itemsAdapter = new ArrayAdapter<String>(this,
                R.layout.activity_task,
                R.id.taskTitle,
                items);
        lvMain.setAdapter(itemsAdapter);
        formButton = (ImageButton) findViewById(R.id.btnPlus);
        formButton.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View v) {
                setLayoutActivity();
    public void setLayoutActivity() {
        setContentView(R.layout.activity_form);
        ImageButton buttonChecked;
        ImageButton buttonUnchecked;
        buttonChecked = (ImageButton) findViewById(R.id.btnChecked);
        buttonUnchecked = (ImageButton)findViewById(R.id.btnUnchecked);
        buttonChecked.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View w) {
                addItems();
        buttonUnchecked.setOnClickListener(new View.OnClickListener() {
            @Override
                commonFunction();
    public void addItems() {
        EditText textTop = (EditText) findViewById(R.id.textTop);
        String itemText = textTop.getText().toString();
        itemsAdapter.add(itemText);
        textTop.setText("");
        writeItems();
        readItems();
        commonFunction();
    private void readItems() {
        File actDir = getFilesDir();
        File save = new File(actDir, "ToDoList.txt");
        try {
            items = new ArrayList<>(FileUtils.readLines(save));
        } catch (IOException e) {
            items = new ArrayList<>();
    private void writeItems() {
        try {
            FileUtils.writeLines(save, items);
            e.printStackTrace();
And here are my XML files :
activity_task
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    android:layout_height="match_parent"
    android:layout_gravity="center_vertical">
    <TextView
        android:layout_width="wrap_content"
        android:layout_height="wrap_content"
        android:id="@+id/taskTitle"
        android:layout_alignParentStart="true"
        android:layout_alignParentLeft="true"
        android:layout_marginTop="4dp"
        android:layout_marginLeft="10dp"
        android:text="Task"
        android:textSize="20sp" />
    <TextView
        android:id="@+id/taskNews"
        android:layout_below="@+id/taskTitle"
        android:text="News"
    <ImageButton
        android:layout_width="65dp"
        android:layout_height="65dp"
        android:id="@+id/btnMinus"
        android:background="#00000000"
        android:layout_alignParentEnd="true"
        android:layout_alignParentRight="true"
        android:layout_marginRight="5dp"
        android:onClick="deleteItems"
        app:srcCompat="@mipmap/ic_minus_foreground"/>
    <ImageButton
        android:id="@+id/btnEdit"
        android:layout_marginRight="75dp"
        android:onClick="editItems"
        app:srcCompat="@mipmap/ic_edit_foreground"/>
</RelativeLayout>
activity_main
Code:
    xmlns:tools="http://schemas.android.com/tools"
    tools:context="com.personal.todolist.MainActivity">
    <ListView
        android:id="@+id/lvMain"
        android:layout_above="@+id/btnPlus" />
    <ImageButton
        android:id="@+id/btnPlus"
        android:layout_alignParentBottom="true"
        app:srcCompat="@mipmap/ic_plus_foreground" />
</RelativeLayout>
activity_form
Code:
    android:layout_height="match_parent">
    <EditText
        android:id="@+id/textTop"
        android:layout_alignParentTop="true"
        android:layout_centerInParent="true"
        android:layout_marginTop="50dp"
        android:ems="10"
        android:hint="Task's title"
        android:textAlignment="center" />
    <EditText
        android:id="@+id/textBottom"
        android:layout_centerHorizontal="true"
        android:layout_centerVertical="true"
        android:ems="10"
        android:hint="Task's news"
        android:inputType="textMultiLine" />
    <ImageButton
        android:id="@+id/btnUnchecked"
        android:layout_marginBottom="50dp"
        android:layout_marginStart="30dp"
        android:layout_marginLeft="30dp"
        app:srcCompat="@mipmap/ic_unchecked_foreground" />
    <ImageButton
        android:id="@+id/btnChecked"
        android:layout_marginEnd="30dp"
        android:layout_marginRight="30dp"
        app:srcCompat="@mipmap/ic_checked_foreground" />
</RelativeLayout>
I tried for 2 days to add the "deleteItems" method and the "editItems" method, but I can't do it. Someone has a solution ?
I would suggest you to create a custom adapter for your listView. It easy for you to do edit and delete items in listView.
