Delete Shortcut
Press it till your phone vibrates then you will see a remove box appear at the bottom of your screen and still keeping it pressed drag it down to the box then release.
Thanks very much! Would you also know how to change my text notification to vibrate for all new incoming messages?
Thanks again!
Thanks again!
Go into Messages tap menu-settings scroll down to the bottom where it says vibrate then check box :)
