Help deleted launcher help
i was playing around with my android and i deleted all my launchers including the android launcher.
i need help with this can someone tell me what to do if i reboot it it gets stuck on the metro pcs screen
HELP ME PLEASE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I would try rebooting into recovery.
To boot into Recovery, hold down the Volume up, Call, and Power button at the same time.
then do a factory reset from there. if that doesn't work.... then someone here will have to give you the stock rom...version of the M835.... whatever you wanna call it.
look here. unleashedprepaids.com/index.php?topic=57.0.
Its a modded stock rom
Have you booted into recovery and done a factory reset? If you haven't, then I would try that. If you have, then did you ever backup your phone? If you have, I would try to restore your backup.
Download the cm7 rom or the mate35 rom on a PC
Put it on your SD card.
Reboot into recovery
Wipe data factory reset
Advanced
Format boot, data, cache, er... damn I'm. Rusty...
Know what. Grab the rom and follow the steps in the ascend ultimate customization guide (Google is your friend ;)
Follow the cwm steps for installing any rom.
my phone says reboot
apply update.zip
factory reset
wipe cache
and frimware uo so what do i press remember i deleted my luacher
You also need the cwm recovery.
Check the aforementioned guide for a tutorial on that too.
You should recognise the person who made the post ;)
OK in recovery mode i rebooted and sometimes it says start up thing stopped working so i am in the lock screen and unlocked it and the closet i can get to settings is wifi settings so i am following your steps now
yea that is it when i try to install it it just say noting found so can i firmware update this to android 2.3.5 gingerbread oor downgrade i dont care just want this fixed
