Hello
I hope someone can help. I have an HTC One X. I recently had to factory reset it. Since the reset I noticed a high volume of data usage. When I looked a little closer it seems that Dialer Launcher is the culprit. I checked the phone itself to see if there is any where that I can stop it from using the internet but couldn't find anything. I've also used Google to find a solution and found a number of people that have the same issue but the only advice I have found is to root your device and this allows you access to stop it. Surely there must be a way of doing this. It wasn't happening before the reset and I haven't installed any apps that I was using before.
Any ideas would be appreciated.
