Dice Bag: Best RPG dice roller for Android
  • Thread starter Thread starter Spherical
  • Start date Start date
S
Spherical
Guest
This is easily the best dice roller out there for gaming. It's got no fancy rolling dice animations, but it's fast and customizable, and lets you add any number of pre-defined rolls. The only thing lacking is dice combos, but apparently that's coming soon. That is, at the moment you can only roll xdy+z, so while you can roll 1d8+5, you can't roll 1d8+1d6+5, nor can you roll 1d8+5 at the same time you roll a separate 1d20+10. Of course, you can set those all up as custom rolls, so that you can certainly do all that just by hitting three different preset rolls.
So it's not perfect, but it's the best out there, and the promised updates will make it very close to perfect.
