Root Did I brick my phone?
ps255
I had take 5 on my phone and I decided I Wanted to sell it so I was going to flash it back to factory well I went and I got the factory 1.6 install from here and proceeded to run ODIN but I accidentally put the PHONE md5 in the PDA slot and tried to run it, I noticed my error and stopped it and put the right files in the right slots, now my phone wont' boot up. when I just power it on it has a green screen. I can get to the download mode just fine and then I try to flash it with ODIN and it will get stuck at starting download, so I will stop and try it again and then I will get stuck at system download, here is what I get
Download Start...
<0> Create File...
<1> StartThread Detected : 1
<2> StartThread Detected : 0
<3> StartThread Detected : 0
<4> StartThread Detected : 0
<5> StartThread Detected : 0
<6> StartThread Detected : 0
<7> StartThread Detected : 0
<8> StartThread Detected : 0
<1> setup connection...
<1> odin mode.. check plcatform verification.
<1> START!!!
<1> check download environment.
<1> partition download..
<1> 1/9 Finished.
<1> arm9boot download..
<1> 2/9 Finished.
<1> arm11boot download..
<1> 3/9 Finished.
<1> amss download..
<1> 4/9 Finished.
<1> kernel download..
<1> 5/9 Finished.
<1> system download..
and it will just sit there FOREVER and the little green bar never gets past 50% I have tried re flashing over and over and over and over and I can never get past either system download, amss download or setup connection.. Please help anyone!
EDIT: I am putting T939UVJA3-BOOTLOADER-20100318.tar.md5 in the boot spot
T939UVJA3-PHONE-20100318.tar.md5 in the phone spot and
T939UVJA3-PDA-20100318.tar.md5 in the pda spot
EDIT:
I decided to do the files separately boot, and then phone and they both went through fine. I just can't get PDA to go now :(
Download Start...
<0> Create File...
<1> START!!!
<1> 1/5 Finished.
and then it just sits there.
Yeah but what Options do I choose? I can get there.. but thats it.
I'm kind of out of a phone right now so I am desperate for any help. Please!
I can format everything except for the system and data it just says error mounting /system error mounting /data I've formatted everything it would let me and tried to flash again and it still sits at system download.
Any one else have any ideas? I really need to get my phone working again. I heard that if I can just get to download mode it is fixable, and I can get my phone to download mode, but I just can't get it to flash no matter what rom I use.
I dont know if this helps but i had the same problem with it getting stuck at system download! I went to another computer and was able to download just fine
what kills me is that i had to re flash my brothers behold 2 on my computer back to factory as well and I used same cord same computer.. crazy :| I am going to try other computers and see if I can get a different cord.
His worked mine didn't :|
Visit Eugenes site:
EB-Productions - Home
He just posted his new rom. Just do the rfs for easy install. Do the recovery then do the rom. Make sure to backup your sd card before you partition it as it will erase everything.
He includes instructions so it won't be hard to follow.
