Difference Between The GT-19300 and the GT-19300T
goat666
I bought a new samsung s3 and the Model number is GT-19300T
Whats the Difference Between The GT-19300 and the GT-19300T
The " t " in i9300t is for the 850MHz band. There is only a small hardware change but basically they are the same phone.
Some carriers here in Australia use the 850MHz band.
Hope this helps.
Hope this helps.
So does this mean that the GT-19300 is faster than the GT-19300T
Thats not the only difference.
when you update the i9300T to version 4.0.4 you can no longer simply tap and hold icons and widgets to move them around like on the i9300 nor can you change the bottom 5 icons anymore.
this gets old VERY fast. i just sold mine and baught an i9300.
Oh. Well i got no issues like that not at all. All good for now
If I understand correctly, my GT-19300T is capable of picking up not only 850MHz but also 900 and 2100MHz? It just seemlessly switches to whichever has the best signal? I read that vfone will be phasing out the 850MHz signal sometime soon. Where I'm coming from with these questions is that I live in Bellbowrie (17km from Brisbane CBD, not mountainous), was tired of constant call dropouts with vodafone so I switched to Amaysim (Optus) for a week and now I've been with Lycamobile (Telstra) for a week. My previous 1-2 bar coverage with vfone has gone to zero to 1 bar at best and can`t make or receive calls unless I go out into the street. Currently investigating whether to go back to vfone or get a 850mhz signal booster (which won't help the others in my family (vfone and optus). Any thoughts? Thanks in advance. p.s. hard to believe we're in 2014, 17km from CBD and can't make or receive calls on my mobile. I'm Australian but previously lived in Spain and had no such problems.
Hope this helps.
Can I assume this means they'd take the same battery? :D
