Digitizer help
rdrain1994
Ok so I have an AT&T s3 and I have to buy a new digitizer for it because I messed it up. I am most likely going to buy one off Ebay and just need to know would the i9300's digitizer be compatible with my kind.
I don't know about ebay i think you should stick with true sellers . Cause if they send u a broken one you are flat lined
