Help Digitizer stoped working after firmware update.
Mike_3001
1.) Model Number = HTC Magic
2.) Firmware Version = 2.1-update1
3.) Baseband Version =63.18.55.06QU_6.35.16.19
4.) Kernel Version = 2.6.29-9cfb347e htc-kernel@and18-2 #1
5.) Build Number = 3.54.631.3 CL220450 release-keys
Also do you have a T-Mobile Data plan on your
PayAsYouGo or FlexPay Plan = no i am on rogers with no data plan atm
Carrier = Rogers (we know some are also Unlocked so not Just T-Mobile)
Country you are using your phone in = Canada
Hello,
i recently updated my htc magic's firmware to version "2.1-update 1" but right after it restarted the touch screen no longer worked. I think the problem has something to do with the new firmware and the digitizer i replaced.
The digitizer does still work but only a space at the top left of the screen(about 2cm x 2cm sapce on the screen) and it is VERY sensitive, moving only a few mm will cause very fast scrolls through menus.
IF anyone has had this problem or knows how to fix it please reply. I'm also looking for a way to reset the firmware back to a later version.
I've tried all the resets, battery pull, back+home+power, but they haven't worked. :(
Any help would be great :)
thanks
